[mapserver-users] Mapscript and Perl CGI::MiniSvr module
Alex Rice
alex_rice at arc.to
Fri Aug 9 09:34:26 EDT 2002
On Friday, August 9, 2002, at 05:21 AM, Nicolas Boretos wrote:
> This sounds similar to what I am doing by using the tclmapscript
> module inside the tclwebserver.
> I load the mapscript module into the interpreter that the httpd
> process also runs in. It seems faster than the mapserv cgi for
> the basic things I am doing, and requires very little overhead.
> A potential bottleneck that I see is that longer running db calls
> would block the webserver. To this end we are looking into
> threading, or at least to move potential db requests back into
> the mapserv.cgi.....
Interesting! In this scenario, are you using Apache as well, or
is the main web server the tclwebserver? Just trying to figure
how the bottleneck would happen with db calls blocking the
webserver.
Alex Rice, Software Developer
Architectural Research Consultants, Inc.
alex_rice at arc.to
alrice at swcp.com
