[mapserver-users] mapserver.log (was Re: malformed PNGs)
woodbri at swoodbridge.com
Wed Aug 14 07:57:52 EDT 2002
On 13 Aug 2002 at 23:23, Puneet Kishor wrote:
> ok. so I am now watching the log file with
> tail -f ...
> and I see the following...
> Tue Aug 13 23:10:51 2002 - msSearchDiskTree(): Unable to access file.
> Tue Aug 13 23:11:46 2002 - msSearchDiskTree(): Unable to access file.
These are informational messages that indicate the you do not have
spatial indexes on some of your shape files -- these would be the
filename.qix. You should run shapetree on every shape files.
If you don't, then you get these messages and mapserver has to either
do a linear search of the shape file or build a temporary shape tree.
This happens on every mapserver hit so adding the shapetree files can
improve performance maybe significantly depending on your set up.
-Steve
