[mapserver-users] multiple symbols prob./ Perl on OS X/ summary and workaround.
Alex Rice
alex_rice at arc.to
Thu Aug 15 15:27:23 EDT 2002
Since it's not unlikely other OS X/ Perl Mapscript developers
will hit this bug (or have already)
On OS X I ran into the situation where Perl Mapscript and DBD::Pg
(The PostgreSQL driver for DBI) both were statically linked with
libpq.a (the PostgreSQL client library).
The symptom was that scripts using both of these modules
(actually not just mapscript; any two Perl modules statically
bound to libpq.a) will die with this output from dyld:
dyld: perl multiple definitions of symbol _DLAddHead
/Library/Perl/darwin/auto/mapscript/mapscript.bundle definition
of _DLAddHead
/Library/Perl/darwin/auto/DBD/Pg/Pg.bundle definition of _DLAddHead
It's a mystery because all of these perl modules were compiled
with -flat_namespace, which I thought was supposed to fix all
this on OS X.
The workaround is to use the environment variable
DYLD_FORCE_FLAT_NAMESPACE. You can set it with setenv in your
shell before running your scripts, or use other Unix methods.
Strangely enough the typical Perl way does not work as expected:
#!/usr/bin/perl
# set at compile time (but doesn't work as expected)
BEGIN { $ENV{'DYLD_FORCE_FLAT_NAMESPACE'} = 1; }
use mapscript;
use DBI;
Instead I am using Apache's SetEnv directive, since this is a CGI
script that's being run:
<Directory "xxx/yyy">
# prevent libpq.a symbol collisions between mapscript and DBI.
SetEnv DYLD_FORCE_FLAT_NAMESPACE 1
</Directory>
Alex Rice, Software Developer
Architectural Research Consultants, Inc.
alex_rice at arc.to
alrice at swcp.com
