[mapserver-users] oracle spatial 9i
Mackey Timothy
Timothy.Mackey at ga.gov.au
Tue Aug 20 00:08:00 EDT 2002
Hi Rodrigo,
We're using Oracle 9.2.0.1.0, and IAS 1.0.2.2.0.
We have installed the version of Oracle Spatial that came with Oracle 9i (release 2).
The 3.6.1 code compiles fine, but requesting a map using mapserver CGI gives a mapserver error: "msOCIConnect() in msOracleSpatialLayerOpen(): OracleSpatial error."
MapServer version 3.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SDE INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Tim
-----Original Message-----
From: Rodrigo Zanato Tripodi [mailto:tripodi at cttmar.univali.br]
Sent: Tuesday, 20 August 2002 1:54 PM
To: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] oracle spatial 9i
I'm working with Rodrigo Cabral at Oracle Spatial support for mapserver.
Sorry about the lack of support. I was busy with a project at the last weeks.
I never tried to compile the mapserver with OCI libs from Oracle 9i. But, I
will test this at this week and try to fix the code if I found any error.
Can you send me the version of all libraries and the error that you get?
Are you using Oracle IAS?
Laboratório de Computação Aplicada - CTTMar/Univali
http://g10.cttmar.univali.br
At 16:55 19/08/02 +1000, Mackey Timothy wrote:
>Hi all,
>I've got mapserver 3.6.1 CGI to compile and work with Oracle Spatial
>8.1.7. However, when I compile and run against Oracle 9i (9.2.0.1.0) I get
>an OracleSpatial error.
>Does Oracle Spatial support only work with 8.x? If so, is it on the plans
>to upgrade to 9i?
>Tim Mackey
>Web Applications Manager
>Geoscience Australia
>timothy.mackey at ga.gov.au
>http://www.ga.gov.au
