[Mapserver-users] Bad SDE query
Jan Hartmann jhart at frw.uva.nl
Tue Dec 3 04:43:43 EST 2002
I'm not sure, but try leaving the quotes out in the second example
(number variables can go unquoted):
([CODE] eq 5201 or [CODE] eq 5201)  # why twice the same?
Jan Hartmamm
Murray, Ross wrote:
> If I dynamically create a query of my shapefile-based map as
> ('[CODE]' eq '3a' OR '[CODE]' eq '3b')
> there are some darn cool results (even if I say so myself). Yet this
> ('[CODE]' eq '5201' OR '[CODE]' eq '5201')
> indentically constructed query on another (SDE layer) map produces the
> following error
> msSDELayerWhichShapes(): SDE error. SE_stream_query(): Invalid SQL syntax.
> (-42).
> If I have the same query templates for each attempt, can anyone suggest why
> I might be getting the worse result?
>  <<Murray, Ross.vcf>>
