[mapserver-users] Does anybody use Mapserver and Tomcat on
Wi n2000??
Erik Van der Goot
erik.van-der-goot at jrc.it
Mon Dec 2 04:45:39 EST 2002
Hi Luca,
thanks for the reply.
Yes, the CGI is configured fine, I can see that I am actually talking to
mapserv.exe when it produces the GIFs. The problem is that it does not talk
back to me.
For your information, I have configured the CGI servlet as a part of my
web application and this works ok.
Thanks again, although I still have no idea where the problem might be.
I'd like to know what mapserv is trying to do once it produces the GIFs in
the temp directory. That way perhaps I can find out what the problem is.
Erik
At 08:25 02/12/2002 +0100, Luca Palli wrote:
>No idea on your problems!
>But you have well configurated your Tomcat?
>In the Tomcat documentation (CGI HOW-TO) there are two operation to make cgi
>working:
>1. Rename $CATALINA_BASE/server/lib/servlets-cgi.renametojar to
>$CATALINA_BASE/server/lib/servlets-cgi.jar
>2. Remove the XML comments from around the CGI servlet and servlet-mapping
>configuration in $CATALINA_BASE/conf/web.xml
>Ciao Luca
> > -----Original Message-----
> > From: Erik Van der Goot [mailto:erik.van-der-goot at jrc.it]
> > Sent: vendredi, 29. novembre 2002 14:27
> > To: Luca Palli
> > Subject: RE: [mapserver-users] Does anybody use Mapserver and
> > Tomcat on
> > Wi n2000??
> > Hi Luca,
> > thanks for your answer.
> > I hope you don't mind me mailing you directly.
> > When you say 'it works only in browse mode' what do you mean
> > exactly?? I am
> > not (but hope to become) a true mapserver user.
> > I have installed the Tomcat CGI servlet in my web application, and
> > mapserver lives in the correct directory.
> > I have modified the demo-html.init file and the map file as per the
> > instructions. When I click on the button I can SEE that
> > mapserver produces
> > 4 .gif files in the temp directory (on the server of
> > course)that I have
> > specified.
> > So... my CGI is working (also when I look at the Tomcat
> > logfiles it is
> > clear that it finds the .exe) , mapserver is working (to some
> > extent, I get
> > the 4 gifs in the temp directory).. BUT it never talks back
> > to me...my
> > browser just sits there
> > Do you have any ideas why that could be??
> > Is there a way I can get mapserv to log what it is doing?
> > Grazie mille
> > Ciao
> > Erik
> > At 09:29 29/11/2002 +0100, you wrote:
> > >Yes, but it works only in browse mode.
> > >In map (for legend reference and scalbar is the same) mode
> > Tomcat send the
> > >image as texts and change some bytes.
> > >For exemple the byte 90 is a reserved byte in Windows and
> > Tomcat transform
> > >it to 3F "?".
> > > > Sent: jeudi, 28. novembre 2002 15:06
> > > > To: mapserver-users at lists.gis.umn.edu
> > > > Subject: [mapserver-users] Does anybody use Mapserver and
> > Tomcat on
> > > > Win2000??
