[Mapserver-users] adding objects
Stepan Kafka stepan.kafka at centrum.cz
Tue Dec 3 11:20:49 EST 2002
  current version of mapscript enables adding object to EXISTING shapefile
(I use it frequently).
The shapefile may be opened like this:
ms_newShapefileObj("filename", -2)
Stepan Kafka
> -----Pùvodní zpráva-----
> Od: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]za u¾ivatele Lowell
> Filak
> Odesláno: 3. prosince 2002 16:48
> Komu: Sven Jacobi; mapserver-users at lists.gis.umn.edu
> Pøedmìt: Re: [Mapserver-users] adding objects
> If by layer you mean shapefile:
> To "add" features to an existing shapefile you need to actually
> create a new shapefile object and loop through each of the
> features in the existing shapefile and add them to the new shapefile.
> Then before closing the shapefile object you can add new features
> to it and then overwrite the old shapefile with the new version.
> Why?
> There is more discussion in the archives regarding that but for
> the most part the original shapefile design (if I understand
> correctly) was for quick read access and not write access.
> There is a PerlMapscript example towards the top of (look for
> "Does the shapefile already exist or is it yet to exist."):
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples35ex8
> And, yes, we actually use that script to add features to a shapefile.
> HTH
> Lowell F.
> The following message was sent by Sven Jacobi <jacobi at dfki.de> on
> Tue, 03 Dec 2002 11:48:31 +0100.
> > Hi,
> > does anybody know whether it is possible to add objects to a
> certain layer?
> > It would be great if an user would have the possibility to add
> an object to
> > a map when he is sure that the map has to be "updated".
> > Any ideas or experiences?
> > Cheers,
> > Sven
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
