[Mapserver-users] Wind Barbs / Truetype font annotation?
Joe Bussell joe at otsys.com
Tue Dec 3 12:46:46 EST 2002
I had the worst time with creating custom symbols until someone passed
me a link which suggested that I needed to declare them in a symbolset
file.  I offer that you should create such a file and reference it in
your mapfile with the SYMBOLSET <filename> directive.  I believe this is
reletive to the shape path, but am not totally sure.
Good luck.  If you get something nice I would love to use it for an
internal project here.
Cordially,
Joe Bussell
On Time Systems
www.trafficdodger.com
Luke Wallace wrote:
> I've been working on the Texas Mesonet project, and am trying to get
> Wind Barb plots for each of the sites based upon their wind speed and
> direction.  I've looked through the archives, but the bits of code I've
> found don't seem to work when combined together.  Below are the
> important parts of my main mapfile
> SYMBOL
>  NAME 'circle'
>  TYPE ELLIPSE
>  POINTS 1 1 END
>  FILLED TRUE
> END
> SYMBOL
>   NAME 'wind1'
>   TYPE truetype
>   FONT 'Esri_Weather'
>   FILLED true
>   ANTIALIAS true
>   CHARACTER "&#98;"        # symbol number in character map
> end
> # Working Point Layer
> LAYER
>  NAME weather-metar
>  TYPE POINT
>  DATA currentWeather
>  STATUS ON
>  LABELCACHE OFF
>  TOLERANCE 10
>  CLASS
>    NAME 'Weather Stations'
>    COLOR 100 200 164
>    SYMBOL 'circle'
>    SIZE 7
>    TEMPLATE "weather_refresh.html"
>  END
> END
> # Non-working Barb Layer
> LAYER
>  NAME weather-barbs
>   STATUS DEFAULT
>    TRANSFORM FALSE
>    TYPE ANNOTATION
>    DATA currentWeather
>    CLASS
>       EXPRESSION "([WINDSPD] = 0)"
>       SYMBOL 'wind1'
>       SIZE 25
>     COLOR 0 0 0
>    END
> END
> I realize I'm going to need more classes (with more expressions) to get
> this to be a truly correct barb, but I'm trying to take small steps and
> just get any symbol to show.
> The following layer in my mapfile puts a single barb in the lower left
> corner of the map. This shows my fontset is set up correctly (right?).
> LAYER
>    NAME credits
>    STATUS DEFAULT
>    TRANSFORM FALSE
>    TYPE ANNOTATION
>    FEATURE
>      POINTS 4 696 END
>      TEXT '&#98;'
>    END
>    CLASS
>      LABEL
>        TYPE TRUETYPE
>        FONT Esri_weather
>        SIZE 50
>        ANTIALIAS true
>        COLOR 0 0 0
>        POSITION UR
>      END
>    END
> END
> _________________________________________________________________
> Protect your PC - get McAfee.com VirusScan Online
> http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
