[Mapserver-users] Change the thickness of the lines in MapServer
Oliver Wesp
wesp at gdv.com
Thu Dec 5 07:35:52 EST 2002
Maybe it's possibe to use an overlaysymbol just to draw the outlines
using a symbol on top of the regular polygon fill. Would be something
like that
CLASS
EXPRESSION /./
COLOR 0 0 0
OVERLAYSYMBOL 'yourSymbol'
OVERLAYCOLOR 255 0 0
OVERLAYSIZE 3
END
Manuel Marichal Pérez schrieb:
> Hi all.
> Does anybody know if it's possible to change the thickness of the lines
> (in polygons layers) in MapServer?.
> I'm unable to do that.
> If I use a SYMBOL to do that all is right when the layer is not filled.
> But if the layer is filled, then the symbol is used to fill the layer
> instead of the border of it.
> Anybody know a way to increase the thickness of a FILLED layer?.
> Thanks,
> Manolo
Dipl.-Geogr. Oliver Wesp
Gesellschaft für geografische Datenverarbeitung
Binger Strasse 49-51
D-55218 Ingelheim
fon: +49 6132 714818
fax: +49 6132 714828
http: www.gdv.com
