[Mapserver-users] Drawing labels beneath a certain layer?
Daniel Morissette morissette at dmsolutions.ca
Thu Dec 5 09:16:35 EST 2002
Vinko Vrsalovic wrote:
> I want to draw the labels of a certain layer before another layer (so
> that the labels will be covered by this other layer).
> Is this possible? (Without creating another layer just with texts)
Assuming you are using MapScript, if instead of $map->draw() you use a
for() loop to call $layer->draw() on every layer, then you can call
drawLabelCache() in the middle of the loop to draw the labels.  Only
problem is you will have to clear the label cache and I don't think a
function exists for that yet in the PHP version... duh!
(http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=207)
Well, as long as you don't call drawLabelCahce() again you should be
fine.
Daniel
 DM Solutions Group              http://www.dmsolutions.ca/
