[Mapserver-users] FAQ: Extent help
Lowell Filak lfilak at medinaco.org
Fri Dec 6 14:37:26 EST 2002
There is a shpinfo.pl script distributed as part of mapserver->mapscript that will display the bounding box of the specified shapefile.
You could use that as a starting point for the EXTENT.
HTH
Lowell F.
The following message was sent by Martin Sarsale  <lists at runa.sytes.net> on Fri, 6 Dec 2002 12:15:59 -0300.
> Dear All:
> Im trying to set up a mapserver for our wireless lan. We want show on a map our Access Points.
> Im testing the program with a shape I got from a friend, but I've no clue on what to put on the 'EXTENT' attribute.
> I was searching thru the mailing list and I found some people asking the same question, but nobody answered them. On other thread I found that the units in 'EXTENT' are the same as in the shape, but I've no idea on which unit is this testing shp.
> Thanks in advance.
> Martin
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
