[Mapserver-users] Yet another beginner
Lowell Filak
lfilak at medinaco.org
Mon Dec 9 11:43:30 EST 2002
For question #1:
There may not be a manual for that but there are samples in the wiki:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples35
There is even a sample of plotting earthquakes.
It reads a text file as opposed to a DBI connection but it's a start.
There is also a sample that uses a DBI fashion connection to XBase where the only difference in your case should be the DBD used.
For question #2:
Mapscript is actually a Perl module so you can directly access the supported mapserver objects & methods within perl.
How:
Step 1:
See the Perl Mapscript install notes:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptBuild35
Step 2:
Include mapscript in your Perl script:
"use mapscript;".
You don't actually use the mapserv executable at all.
You could if you really wanted to via the "system" call and constructing the appropriate "get" string but using Mapscript is a much better choice.
HTH
Lowell F.
The following message was sent by Agneta Schick <schick at sdac.hannover.bgr.de> on Mon, 9 Dec 2002 17:10:36 +0100 (MET).
> Hello,
> Environment: SunSolaris8, Ingres RDBMS, Apache, MapServer3.6, Perl, DBI
> Goal: start MapServer from an application, and allow db queries
> Experience: I've installed the Mapserver, got the Itasca demo running,
> some of Tutorial35 and my own map (raster).
> Next step: I want to add symbols for earthquakes
> (geographical coordinates). These are stored in our DB.
> >From the Mapserver homepage:
> "For example, using Perl's DBI module it is possible to integrate data from just
> about any database vendor (eg. Oracle, Sybase, MySQL) with traditional GIS data
> in a single map graphics or web page."
> Question 1: >>>HOW?<<<< Just tell me which manual to read!
> Question 2: is it possible to start the Mapserver from a Perl application? How?
> I'm asking these questions at an early stage to be sure the Mapserver is the
> right tool for us.
> Thank you,
> Agneta Schick
> Agneta Schick
> Bundesanstalt fuer Geowissenschaften und Rohstoffe
> Federal Institute for Geosciences and Natural Resources
> Stilleweg 2
> D- 30655 Hannover Tel.: +49 511 643 3136
> GERMANY FAX.: +49 511 643 3663
> schick at sdac.hannover.bgr.de http://www.seismologie.bgr.de
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
