[Mapserver-users] Measured shape file mapserver compatibility
Yewondwossen Assefa
assefa at dmsolutions.ca
Wed Dec 11 09:57:49 EST 2002
Hi there,
Support of measured shape file has been added since mapserver 3.5X. Measure
files supported are Points, Arcs, Polygon and Multipoints. Note that only the
Arcs have been tested properly.
You can access the m value of a point object as you access the x and the y.
Please refer to the php/mapscript README on this.
There are also a couple of utility functions that may or may not be useful to
you :
- getpointusingmeasure : Given a measure m, retun the
corresponding XY location on the shapeobject.
Ex : point = shape->getpointusingmeasure(100);
//display point->x, point->y
- getmeasureusingpoint : Given an XY Location, find the
nearest point on the shape object. Return a point object
of this point with the m value set.
Note : To locate the nearest point, we will use a line
which is perpendicular to the nearest segment and passes
through the point.
Ex : *
\ *(XY)
* <--------------- intersection
seg1 \
seg2
Later,
Claude Philipona wrote:
> Hello,
> Is Mapserver/PHPMapscript compatible with measured shape files. I found some
> indication about measured shape files in the mapscript class documentation,
> but without much information about.
> Is there somewhere more information (howto or hint) about to use this
> feature (if it really exist)? What are the limitations with measured shape
> files.
> Thanks,
> Claude
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
