Doh! (Re: [Mapserver-users] python mapscript)
Sean Gillies sgillies at frii.com
Thu Dec 12 11:07:55 EST 2002
Sean Gillies wrote:
> Sven Jacobi wrote:
>> Hello,
>> I'm using Mapserve3r inside Zope and want to create
>> several layers. As long as I use the normal shapefiles
>> as DATA in my mapfile this works fine. But when I want to have a map
>> given from a "picture" (tif)
>> I get "Bus errors" from python.
>> Below is a small piece of code, have I forget to call some
>> functions?
>> def drawmap():
>>  mymap = mapObj("/home/jacobi/...")
>>  mymap.width=600
>>  mymap.height=400
>>  myimage=mymap.draw()
>>  out = myimage.saveImage("blies.png",MS_PNG,50,0,50)
>>  return out
>> drawmap()
>> Any ideas or hints?
>> Thanks in forward,
>> Cheers,
>> Sven
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Sven,
> Python is not raising a bus error, so the error is most
> likely due to problems with your mapscript C lib.  Have
> you tried using a TIFF as a raster layer before?  Are
> you using GDAL to access the TIFF?  There are many
> possible problems, you should provide a bit more data
> to help with the diagnosis:
> Operating system, software (version/revision), compiler,
> Python distribution, etc.
> cheers,
> Sean
Sven,
I wish I'd waited to send that previous email.
The first 'gotcha' I encountered when I started using
Python Mapscript and Zope was due to a Python version
difference.  Zope 2.4-6 use Python 2.1.  If you've
been using Python 2.2 (as I had been), you will need
to rebuild mapscript using Python 2.1.
You should be able to use the Python that comes with
Zope, for example:
/var/zope/bin/python setup.py install
Or something like that.  Hope this helps.
# Sean Gillies
# sgillies at frii.com
