[Mapserver-users] trouble using postgis layer
Steve Lime
steve.lime at dnr.state.mn.us
Thu Dec 12 11:57:03 EST 2002
Paul is right. MapServer applies a regular expression pattern for a
number to
all numeric input and gives this error if the test fails. Use get
instead of post
and look at the submitted values closely to see where the error might
be.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Paul Ramsey <pramsey at refractions.net> 12/12/02 10:42AM >>>
I quick grep of the mapserver source indicates that getNumeric is used
to read parameters sent into the cgi program. So the problem is likely
not your mapfile, but how you are calling mapserver... my 2 second
guess.
P.
Alessandro Ceccotti wrote:
> Hello listers!
> I'd finally managed to configure and correctly install postgis and
> mapserver.
> I've inserted the following postgis layer in mt .map file:
> LAYER
> CONNECTIONTYPE postgis
> NAME "demo"
> # Connect to a remote spatial database
> CONNECTION "user=user dbname=db host=localhost"
> # Get the lines from the 'the_geom' column of the 'mappe1'
table
> DATA "the_geom from mappe1"
> STATUS ON
> TYPE line
> END
> END
> when i run mapserver, it returns me an error message:
> getNumeric(): Incorrect data type.
> I dont know on what it depends...
> I've tried to change the TYPE definition into polygon, but the error
> persists...
> Any tips?
> thanks
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
