[Mapserver-users] Umlauts in labels
Oliver Wesp wesp at gdv.com
Fri Dec 13 05:07:47 EST 2002
Hi Björn,
we're using labels that contain umlauts without any problems at all.
We're using ms 3.6.3 on Win2000, Solaris and on both platforms the
umlauts display fine. We're using bitmap and truetype fonts. Data
sources are shapefiles, ArcSDE-Layer and layer from oracle spatial. In
   neither of these settings we have problems using umlauts. Don't know
if the problem is ms 3.5 but have you checked your datasources. Most of
the times I had such trouble the umlauts where screwed up in the DBF of
a Shapefile.
greetings
Oliver
Björn Platzen schrieb:
> Hello list,
> I have made a small mapserver-application with HTML-Templates using ms 3.5 on
> RH Linux 7.? .
> Now, it's the map of a German Town (Aachen) and in most of the streetnames
> there are umlauts (ß, ü, ö, ...).
> Is there any way to support Umlauts in Labels with MapServer?
> Thanks in advance for any help.
> Bjoern Platzen.
Dipl.-Geogr. Oliver Wesp
Gesellschaft für geografische Datenverarbeitung
Binger Strasse 49-51
D-55218 Ingelheim
fon: +49 6132 714818
fax: +49 6132 714828
http: www.gdv.com
