[Mapserver-users] embed scalebar question
Lowell Filak lfilak at medinaco.org
Fri Dec 13 13:25:06 EST 2002
You may have already tried this...
However, if you create a mapfile and include in the mapfile the embedded scalebar how does the output look?
The first step is to make sure that the image is generating correctly without creating or editting the scalebar object inside of mapscript.
Lowell F.
The following message was sent by Vincent Jansen <vincent at javel.nl> on Thu, 12 Dec 2002 14:07:20 +0100.
> Hi list,
> I'm running perl mapscript 3.6.3 on a suse linux box.
> When I try to embed a scale bar it alway appears out of place with labels
> drawn in single pixel fonts
> When drawing the scalebar separately, all works fine.
> Anyone?
> Or does anyone how to embed pictures using perl.
> Thanks,
> Vincent Jansen
> Javel BV
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
