[Mapserver-users] another perl mapscript problem
Lowell Filak lfilak at medinaco.org
Tue Dec 17 13:35:05 EST 2002
If you change your saveImage line so the image is saved to a system file and then:
system("cat $image_name");
do you get the same error?
If so then $query may not be setup correctly and is indeed not forwarding the content-type.
You mentioned you already tried sending content-type manually, do you mean:
print "Content-type: image/gif\n\n";
Lowell F.
The following message was sent by Dana Quinn <dana at nextbus.com> on Tue, 17 Dec 2002 10:11:19 -0800.
> Hi - I'm having another perl mapscript problem, and I
> was hoping someone could help me find a clue.  Basically,
> I'm trying to get a pre-existing perl cgi we have working
> with the 3.6.3 version of mapserver, perl 5.8, and
> RedHat Linux 8.0.  I'm almost there, and I think probably
> some stupid problem is keeping me from finishing this.
> Here's a code snippet - we've done all our image creation
> work, and we're ready to output it to the browser - (we
> are using CGI.pm, btw):
> print $query->header('image/gif');
> $img->saveImage(undef,$mapscript::MS_GIF, $map->{transparent},
> $map->{interlace}, 0);
> very simple, yeah?  If I change the 'saveImage' call to write
> to a file on the filesystem, it works perfectly, I get a
> saved gif that I'm able to view, and it works great.
> If I use undef, like above, to output to the browser, I
> get a '500 Server Error', and get this in my server error
> logs:
> [Mon Dec 16 18:29:28 2002] [error] [client 64.164.28.194] malformed
> header from script. Bad header=GIF87aX^B<F4>^A<E7>:
> /usr/local/apache/cgi-bin/mapserv.pl
> It kinda looks like the browser isn't seeing the Content-Type
> header...  but that's what the 'query->header' business is
> supposed to do.  So I've tried printing it by hand, no dice.
> There must be some stupid thing I'm missing - does anyone have
> any ideas what I'm doing wrong?
> Dana
> Dana Quinn, dana at nextbus.com
> NextBus Information Systems
> (510) 420-3117
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
