[Mapserver-users] Perl Mapscript (with Mapserver-3.6.3) on
Redhat 8 compiles, but returns __gxx_personality_v0 when tested
Jonathan W. Lowe
jlowe at giswebsite.com
Tue Dec 17 15:23:32 EST 2002
Dana,
Thank you *so much* for the detailed explanation of how to compile perl
mapscript on redhat 8. IT WORKED!! In my case, the change was from gcc
to c++, but the result was a working mapscript.pm module. Both of the
example perl mapscripts run perfectly. Hooray!
One thousand thanks!
Jonathan
On Tue, 2002-12-17 at 10:59, Dana Quinn wrote:
> Jonathan, etal-
> I had the same problem using perl mapscript. I think you
> basically need to compile the lib with c++ instead of the regular
> gcc. The way I did it was really low tech, because I couldn't
> figure out what needed to be in Makefile.PL or Makefile.
> here is exactly what I did: (my build environment is sorta
> strange, don't worry about all the extra -I's)
> [prompt]$ perl Makefile.PL
> -I/u1/src/ms/mapserver-3.6.3 -I/u1/src/ms/proj/include -I/u1/src/ms/gd
> -L/u1/src/ms/mapserver-3.6.3 -lmap -L/u1/src/ms/gd -lgd
> -L/u1/src/ms/freetype2/lib -lfreetype -lz -L/u1/src/ms/freetype2/lib
> -lfreetype -lz -L/u1/src/ms/proj/lib -lproj -lm
> Writing Makefile for mapscript
> [prompt]$ make
> cp mapscript.pm blib/lib/mapscript.pm
> cc -c -I/u1/src/ms/mapserver-3.6.3 -I/u1/src/ms/proj/include
> -I/u1/src/ms/gd -fno-strict-aliasing -D_LARGEFILE_SOURCE
> -D_FILE_OFFSET_BITS=64 -I/usr/include/gdbm -O3 -DVERSION=\"\"
> -DXS_VERSION=\"\" -fpic "-I/usr/local/lib/perl5/5.8.0/i686-linux/CORE"
> -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H
> -DUSE_GD_GIF -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR
> mapscript_wrap.c
> Running Mkbootstrap for mapscript ()
> chmod 644 mapscript.bs
> rm -f blib/arch/auto/mapscript/mapscript.so
> LD_RUN_PATH="/u1/src/ms/mapserver-3.6.3:/u1/src/ms/gd:/u1/src/ms/freetype2/lib:/usr/lib:/u1/src/ms/proj/lib:/lib"
> cc -shared -L/usr/local/lib mapscript_wrap.o -o
> blib/arch/auto/mapscript/mapscript.so -L/u1/src/ms/mapserver-3.6.3
> -lmap -L/u1/src/ms/gd -lgd -L/u1/src/ms/freetype2/lib -lfreetype -lz
> -L/u1/src/ms/freetype2/lib -lfreetype -lz -L/u1/src/ms/proj/lib -lproj -lm
> chmod 755 blib/arch/auto/mapscript/mapscript.so
> cp mapscript.bs blib/arch/auto/mapscript/mapscript.bs
> chmod 644 blib/arch/auto/mapscript/mapscript.bs
> then - I took the last line that ran cc - copy and paste it back onto
> the command line, and then edit the 'cc' to be 'c++'
> and then run it:
> [prompt]$
> c++ -shared -L/usr/local/lib mapscript_wrap.o -o
> and as far as I can tell, the lib works fine. sorry for the bad
> linewrap, hopefully you get the idea. Hopefully someone smarter than me
> can figure out how to include this in configuration. :)
> Dana
> Jonathan W. Lowe wrote:
> > List:
> > Has anyone successfully compiled and run Perl Mapscript (from the
> > Mapserver-3.6.3 distribution) on Redhat 8?
> > Thanks to the mapserver-user list archive, I was able to install
> > mapserver-3.6.3 on redhat 8 successfully by replacing (CC) with (CXX)
> > such as in the following example:
> > Original:
> > shp2img: libmap.a shp2img.o map.h
> > $(CC) $(CFLAGS) shp2img.o $(LDFLAGS) $(STATIC_LIBS) -o shp2img
> > Changed to:
> > $(CXX) $(CFLAGS) shp2img.o $(LDFLAGS) $(STATIC_LIBS) -o shp2img
> > Perl Mapscript also compiles when the line...
> > SWIGEXPORT(void) boot_mapscript(CV* cv);
> > ...is replaced with...
> > XS(boot_mapscript);
> > ...in the mapscript_wrap.c file.
> > However, when referencing the resulting mapscript.pm module in a perl
> > script (see reference example below), the dreaded __gxx_personality_v0
> > raises its ugly head (see error details below). Have any others on the
> > list succeeded in compiling and running perl mapscript on redhat 8?
> > Example of ms_test.pl script reference to perl mapscript:
> > #!/usr/bin/perl -w
> > use lib
> > '/home/gisweb/local/lib/perl5/site_perl/5.8.0/i386-linux-thread-multi';
> > # Location of mapscript.pm
> > use mapscript;
> > # --- End of ms_test.pl --- #
> > The resulting error message when running "perl ms_test.pl":
> > Can't load
> > '/home/gisweb/local/lib/perl5/site_perl/5.8.0/i386-linux-thread-multi/auto/mapscript/mapscript.so' for module mapscript: /home/gisweb/local/lib/perl5/site_perl/5.8.0/i386-linux-thread-multi/auto/mapscript/mapscript.so: undefined symbol: __gxx_personality_v0 at /usr/lib/perl5/5.8.0/i386-linux-thread-multi/DynaLoader.pm line 229.
> > at
> > /home/gisweb/local/lib/perl5/site_perl/5.8.0/i386-linux-thread-multi/mapscript.pm line 7
> > Compilation failed in require at ms_test.pl line 3.
> > BEGIN failed--compilation aborted at ms_test.pl line 3.
> > An advanced thank you for any advice or suggestions,
> > Jonathan W. Lowe
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Dana Quinn, dana at nextbus.com
> NextBus Information Systems
> (510) 420-3117
