[Mapserver-users] trouble with querymap
David Rafkind daver at umiacs.umd.edu
Tue Dec 17 18:58:43 EST 2002
hello all! a quasi-newbie question about mapserver 3.6.3:
I am trying to highlight point-selected features in a layer. I assume this
happens by setting the "mode" cgi variable to "querymap". This is the URL
I am trying to use:
http://ironclad.umiacs.umd.edu:8000/cgi-bin/MapServer?mode=querymap&map=/ironclad/daver/lv/www/data/map-data/usa.map&layer=states&qlayer=states&slayer=states&mapsize=392+372&imgsize=392+372&mapext=-80.5194+38.22755141388174+-74.696+43.76184858611826&imgext=-80.5194+38.22755141388174+-74.696+43.76184858611826&img.x=196&img.y=186
It is quite long because I am shooting the moon and including lots of cgi
variables in the hopes that one will work.
The imgext and mapext are the same, the layer, qlayer, and slayer are the same.
I did notice that including img.x and img.y produces a different error than
including imgxy. The img.x and img.y are set to the middle of the image, which should
be pennsylvania. Here is the URL with the mode changed to "map", for reference:
http://ironclad.umiacs.umd.edu:8000/cgi-bin/MapServer?mode=map&map=/ironclad/daver/lv/www/data/map-data/usa.map&layer=states&qlayer=states&slayer=states&mapsize=392+372&imgsize=392+372&mapext=-80.5194+38.22755141388174+-74.696+43.76184858611826&imgext=-80.5194+38.22755141388174+-74.696+43.76184858611826&img.x=196&img.y=186
Can anyone tell me what I am doing wrong? I am sure it is something really obvious.
(I've seen other similar complaints in the mailing list archive but nothing
with the same particulars)
Here is my map file:
map
Name usa
ImageColor 0 0 32
ImageType png
ShapePath "."
QUERYMAP
    STATUS ON
    STYLE HILITE
    COLOR 255 0 255
END
Layer
    ConnectionType postgis
    name "states"
    Connection "user=daver password=password dbname=testdb"
    Data "the_geom from states"
    Status on
    type polygon
    class
	outlinecolor 255 0 0
	color 64 64 128
    end
End
End
