[Mapserver-users] WMS help
Ed McNierney
ed at topozone.com
Wed Dec 18 14:22:54 EST 2002
Dave -
What build of MapServer are you using? This *might* be related to a bug I ran into (and that Daniel has since fixed) concerning SRS= parameters in GetMap requests.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
Sent: Wednesday, December 18, 2002 1:48 PM
To: Mapserver-Users (E-mail)
Subject: Re: [Mapserver-users] WMS help
Ryan,
Thanks for your help. And, you're right. I got it to work just fine.
Except when I try to project.
The working version of my mapfile (client) contains:
EXTENT -102 33 -94 37
UNITS DD
and no PROJECTION params.
If I change the mapfile (client) to read:
EXTENT -633771.227805 1060738.573036 152927.340425 1689379.870746
UNITS METERS
PROJECTION # ALBERS OK -all drg's and doqq's on geo site are OK ALBERS
proj=aea
lat_1=29.500000000 #SP1
lat_2=45.500000000 #SP2
lat_0=23.000000000 #REF LAT
lon_0=-96.000000000 #CENTRAL MERIDIAN
x_0=0.000 #FALSE EAST
y_0=0.000 # FALSE NORTH
datum=NAD83
ellps=GRS80
no_defs
END
The maps generate just fine for all non-wms layers with the second set of
settings. As soon as I turn on a WMS layer the browser just waits and waits
while mapserv.exe is running on the client web server. The exe is hung. So
it seems to be something with the projections... Would you agree? Ideas?
Dave
Sent: Wednesday, December 18, 2002 11:52 AM
To: 'Lowther, David W'
Subject: RE: [Mapserver-users] WMS help
Hey Dave,
Well, I just added your layer (with some alterations) to my own mapfile, and
it came in just fine. The layer definition I used was:
LAYER
NAME cnty_wms
STATUS ON
TYPE line
CONNECTIONTYPE WMS
CONNECTION
"http://geo.ou.edu/cgi-bin/mapserv.exe?map=wms.map&VERSION=1.1.0&LAYERS=Coun
ties&FORMAT=image/png&TRANSPARENT=TRUE"
PROJECTION #GEOGRAPHIC NAD83
proj=longlat
ellps=GRS80
no_defs
END
METADATA
"wms_title" "County"
"wms_srs" "EPSG:4269 EPSG:4326"
"wms_connectiontimeout" "10"
END
END
Just thought you'd like to know..
Ryan
Sent: Wednesday, December 18, 2002 8:43 AM
Subject: [Mapserver-users] WMS help
Howdy List,
I am trying to setup WMS Server and Client stuff. The files in the doc are
great. I've setup the server, tested XML output, and run it through
cubeview. Evertyhing looks good.
http://geo.ou.edu/cgi-bin/mapserv.exe?map=wms.map&REQUEST=GETCAPABILITIES
http://geo.ou.edu/cgi-bin/mapserv.exe?map=wms.map&VERSION=1.1.0&REQUEST=GETM
AP
Problem is I can't get the client cooking from here.
Here's the layer def from the client mapfile:
LAYER
GROUP "Administrative Boundaries"
NAME cnty_wms
TYPE LINE
STATUS OFF
CONNECTIONTYPE WMS
CONNECTION
ties&FORMAT=image/png"
# DATA county
proj=longlat
ellps=GRS80
no_defs
END
METADATA
legend_order "140"
END
CLASS#
MAXSCALE 100000
SYMBOL "line"
COLOR 98 98 98
SIZE 8
END
CLASS#
MINSCALE 100001
SYMBOL "line"
NAME "County Boundary (WMS)"
COLOR 98 98 98
SIZE 2
END
END
Anybody got any idea what I'm doing wrong here? I don't really understand
the relationship between the server mapfile projection, server layer
projection, client mapfile projection, and client layer projection. Could
this be causing my problems? Can anyone else see this layer?
Thanks for any help,
David Lowther
Software Engineer
GEO Information Systems
dlowther at ou.edu
(405) 325-3131
http://www.geo.ou.edu
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
