[Mapserver-users] PostGIS and Mapscript subselects
Paul Smith paul at cnt.org
Thu Dec 19 18:44:38 EST 2002
FreeBSD 4.6, PHP 4.2.3, PostGIS 0.7.3, Mapserver 3.6.3 w/ latest CVS
mappostgis.c
It seems as though PostGIS subselects only work for me if the Layer
definition is in the .map file, which I'd rather not use, instead of in
PHP. I've combed through the lists and Google, and I can't seem to find
a previous mention of this bug.
Here's my DATA statement:
	the_geom from (select the_geom, oid from grid_streets)
	as foo using unique oid using SRID=-1
(By the way, a plain, non-subselect DATA statement like:
	the_geom from grid_streets
works fine)
If this is in the .map file, ala:
	LAYER
    		DATA "the_geom from (select the_geom, oid from grid_streets)
				as foo using unique oid using SRID=-1"
	END
it's fine. If it's done in PHP, ala:
	$grid_streets = ms_newLayerObj($map);
	$dataSql = "the_geom from (select the_geom, oid from grid_streets)
				as foo using using oid using SRID=-1";
	$grid_streets->set('data', $dataSql);
then I get the following error:
Warning: MapServer Error in prep_DB(): Error executing POSTGIS DECLARE
(the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR
SELECT
street::text,asbinary(force_collection(force_2d()),'NDR'),oid::text
from #3¸ WHERE && setSRID('BOX3D(-87.6720208305802
41.8238094568678,-87.5728089028288 41.9230213846192)'::BOX3D, -1 )'
Postgresql reports the error 'ERROR: parser: parse error at or near "#"
More Help:
Error with POSTGIS data variable. You specified '<check your .map
file>'.
Standard ways of specifiying are :
(1) 'geometry_column from geometry_table'
(2) 'geometry_column from (<sub query>) as foo using unique <column
name> using SRID=<srid#>'
Make sure you put in the 'using unique <column name>' and 'using
SRID=#' clauses in.
For more help, please see
http://postgis.refractions.net/documentation.php
Mappostgis.c - version of Nov 15/2002. in
/usr/local/www/sites/mapserver.cnt.org/docs/index-3-6-3.php on line 547
Fatal error: Call to a member function on a non-object in
/usr/local/www/sites/mapserver.cnt.org/docs/index-3-6-3.php on line 548
Thanks for any help.
Paul
Paul Smith <paul at cnt.org>
Center for Neighborhood Technology
Chicago, IL USA
