[Mapserver-users] (no subject)
Sven Jacobi jacobi at dfki.de
Fri Dec 20 09:11:48 EST 2002
I try to reconfigure mapscript for python and I do it the
way described in the Wiki.
I don't know how to deal with the following error:
gcc -shared build/temp.solaris-2.8-sun4u-2.1/mapscript_wrap.o ../../libmap.a
/home/jacobi/MAP/library/ogrsf_frmts.a /home/jacobi/MAP/library/gdal.a
/home/jacobi/MAP/library/ogr.a /home/jacobi/MAP/library/gdal.a
/home/jacobi/MAP/library/cpl.a -L../.. -L../../gd-1.8.4 -L/lib
-L/usr/local/lib -lgd -lfreetype -lttf -lpng.dll -lproj -lpq -lz -o
build/lib.solaris-2.8-sun4u-2.1/MapScriptc.so
/opt/gnu/sparc-sun-solaris2.8/bin/ld: cannot find -lttf
collect2: ld returned 1 exit status
error: command 'gcc' failed with exit status 1
I have never heard of "LTTF" and have no idea how to install this.
After checking the archives, I've found that it has something to
do with freetype (Am I correct?).
I have freetype-2.0.9 installed, but I can't find "lttf" there...
Any ideas or help ???
Cheers,
Sven
