[Mapserver-users] compile problem with 3.6.3 and php 4.2.2
Daniel Morissette
morissette at dmsolutions.ca
Fri Dec 20 16:25:37 EST 2002
Check that you don't have a /usr/local/lib/libmap.a, and if you do then
delete it and recompile your MapScript.
Also, don't use 'make install' in the MapServer directory any more. One
day I'll get to that and disable the 'make install' in the MapServer
Makefile.
Daniel
> "Aaron D. Hunt" wrote:
> I have compiled mapserver with
> ./configure --without-tiff --with-proj --with-gdal --with-ogr
> --with-jpeg --with-php=/usr/local/src/php-4.2.2/
> When I call a php I get nothing in the browser but I get:
> php: relocation error:
> /usr/local/lib/php/extensions/no-debug-non-zts-20020429/php_mapscript.so:
> undefined symbol: msGetErrorObj
> In the error log when I try to open the map file.
> I run redhat linux.
> Does any one have any ideas.
> Thanks
> Aaron D. Hunt
