[Mapserver-users] sub-select
nida Khan nida at webstar.co.uk
Mon Dec 23 05:30:52 EST 2002
Hi Jan,
Thank you so much for pointing me to that document, it really helped me to
understand the way mapserver understand the queries but I'm still stuck with
my problem.
Before I was getting a blank image, After reading the document I created to
indexes one on the geom. other on oid.
now I chaged srid to SRID as well... and this time I got this error
msPOSTGISLayerWhichShapes(): Query error. prep_DB:Error executing POSTGIS
DECLARE statement (0.6 failed - retried 0.5 and it failed too). DECLARE
mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'XDR'),OID::text from (select
oid, the_geom from westminster) AS foo USING UNIQUE oid USING SRID=-1 WHERE
the_geom && setSRID('BOX3D(145300 170784,366100 391216)'::BOX3D,
find_srid('','westminsterary','the_geom') )
here is my layer
LAYER # start of the "unitary_boundary" layer object
  CONNECTIONTYPE postgis
  NAME "unitary_boundary"
  CONNECTION "host=127.0.0.1 port=5432 user=postgres password=blah
dbname=test"
  DATA "the_geom from (select oid, the_geom from westminster) AS foo USING
UNIQUE oid USING SRID=-1"
  STATUS DEFAULT
  TYPE LINE
  CLASS
    NAME "Unitary"
    COLOR 0 0 0
    OUTLINECOLOR 240 240 240
  END # end of class object
END # end of layer object
With Kind Regards
Nida.
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Friday, December 20, 2002 6:35 PM
Subject: Re: [Mapserver-users] sub-select
> using SRID= ... using UNIQUE=.. are only necessary in subselects, so
> they are not needed in your first two data statements . A description
> for this has recently been added to the docs in
> http://postgis.refractions.net/docs/x549.html#AEN607
> What exactly does the third statement do? Does it return an error or
> just a blank map?
> Jan Hartmann
> nida Khan wrote:
> > hmmmmm... strange
> > its seems really odd, it works other way round for me.
> > when I do
> > the_geom from westminster using unique oid using SRID=-1
> > it does NOT work
> > but this one does
> > the_geom from westminster using unique oid using srid=-1
> > And when I add
> > the_geom from (select oid,the_geom from westminster) as foo using unique
oid
> > using srid=-1
> > it does not display that layer!!!
> > Can you also explain me or point me to a right document which explain
the
> > logic of using "srid"??
> > I'm kinda stuck at this point :(.
> > Thank you very much for your response!
> > Regards
> > Nida.
> > From: "Jan Hartmann" <jhart at frw.uva.nl>
> > Sent: Friday, December 20, 2002 12:55 PM
> >>Nida,
> >>You have to put SRID in capitals!. This is a small but very annoying bug
> >>that has been reported before
(http://postgis.refractions.net/pipermail/postgis-users/2002-November/001757
> > .html)
> >>but has not been resolved yet.
> >>Jan Hartmann
> >>nida Khan wrote:
> >>>Hi Everyone,
> >>>I want to do a subselect from my .map file. I went through some
> >>>list-archive from that I tried these statements.
> >>>DATA "the_geom from westminster"  works fine
> >>>DATA "the_geom from westminster using unique oid using srid=-1"
works
> >>>fine
> >>>DATA "the_geom from (select oid,the_geom from westminster) as foo using
> >>>unique oid using srid=-1"  no result
> >>>I've got two tables, one with geom, other with features... I want to
> >>>display the certain feature as label on the map.
> >>>What I'm missing in the above sql? Am I doing anything wrong? Is there
> >>>anything on database level that I have to change?
> >>>Will Appreciate any inputs
> >>>Regards
> >>>Nida.
> >>Jan Hartmann
> >>Department of Geography
> >>University of Amsterdam
> >>jhart at frw.uva.nl
> >>_______________________________________________
> >>Mapserver-users mailing list
> >>Mapserver-users at lists.gis.umn.edu
> >>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Jan Hartmann
> jhart at frw.uva.nl
