[Mapserver-users] Point shae as lines
daniel.berstein at dmapas.com
Mon Dec 23 07:56:45 EST 2002
I think you should use 2 shape files. One with the nodes/vertices (your
actual shape file) and another for your line segments. Otherwise there is
no way to know how do you want the points "connected".
What does those points represent? Street intersections?
Regards,
Daniel Berstein Z.
Jefe de Proyectos, dmapas.com
Eduardo Hyatt 583, Providencia, Santiago CHILE
*(56) (2) 222 22 60
-----Mensaje original-----
De: Eduardo Spremolla [SMTP:edspremolla at Antel.com.uy]
Enviado el: Viernes, 20 de Diciembre de 2002 14:09
Para: mapserverlist
Asunto: [Mapserver-users] Point shae as lines
Is there a way to link the points of a point shape file with lines.
The shape has information for every point, so a line shape is not
applicable.
I want the line draw, plus a label for each point with some attribute.
Many thanks in advance.
Eduardo Spremolla
Montevideo
Uruguay
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
