[Mapserver-users] PHP Mapscript - Can't label dynamic point
Daniel Morissette morissette at dmsolutions.ca
Mon Dec 23 08:56:41 EST 2002
"Hankley, Chip" wrote:
> I'm having trouble getting the labeling to work. In the following code, I'm
> passing the variable $address_text (which I've checked IS a valid
> string)...however, no text is rendering in the image (although the point IS
> rendering).
Try setting LABELCACHE OFF in your layer, or calling DrawLabelCache()
once you've generated all your labels.
Daniel
 DM Solutions Group              http://www.dmsolutions.ca/
