[Mapserver-users] Mapserver output
Stefan Stern mail2stern at gmx.net
Mon Dec 23 12:40:54 EST 2002
Hi Alessandro,
I ran into the same error. ,-)
1. Does your mapserver application point to the right directory of the
mapfile / shapefile etc.?
2.If a shapefile doesn't appear: you might have used "STATUS ON " in the
LAYER object in the mapfile;
use "STATUS DEFAULT" instead
Hope it helps,
Stefan
http://www.mygeo.info
----- Original Message -----
From: "Alessandro Ceccotti" <alessandro.ceccotti at netxcalibur.com>
To: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, December 23, 2002 4:19 PM
Subject: [Mapserver-users] Mapserver output
> Finally I've managed to make Mapserver and postgis connecting.
> When I call template from web browser (I use mapserv as cgi), the result
is
> a .png picture (as I wanted), but instead of containing my db's data, it
is
> only a white sheet.
> someone can help me?
> my template is as fotllows
> <html>
> <head><title>MapServer Demo Interface</title></head>
> <body bgcolor=#FFFFFF>
> <center><h1>MapServer Demo Interface</h1></center>
> <hr>
> <form method=GET action="[program]">
> <img border="1"
> src="/cgi-bin/mapserv?map=/httpd/virtual/cubavpn/demo1.map&amp;mode=map">
> <input type="checkbox" name="layer" value="demo" [demo_check]> Demo <br>
> </form>
> <p><hr><p>
> </body></html>
> Thanks
>   Alessandro
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
