[Mapserver-users] (no subject)
Lowell Filak
lfilak at medinaco.org
Mon Dec 23 13:17:14 EST 2002
There may be other solutions to this, but are you able to post the mapfile for reference?
Lowell F.
The following message was sent by "RIVONANTENAINA Hery" <riv.hery at dts.mg> on Fri, 20 Dec 2002 10:18:32 +0400.
> I installed MapServer 3.6 on Windows 9x, and it works fine but then I > installed it on Linux Red Hat 7.1 when I started to have a problem. > first I installed the library GD, if the interface shows fine, the icone > actually doesn't, when we looked at the file, it seems that it is > creating a file called demo*.gif which lead us to install the library GD > patched (option GIF) but still get the same error. our question is then > how do we get the icone to show? either in GIF format (it is not in the > file at all) or in JPEG format if we want to use that format?
> Outgoing messages scanned and certified safe by Stop-Sign, the Personal Alarm Service.
> http://defender.veloz.com/dlp_ban/?n=tl&sp .out002
