[Mapserver-users] Configuring the demo_init.html & demo.map files
mapserver at sporinfor.net mapserver at sporinfor.net
Thu Dec 26 01:25:15 EST 2002
You need to place the mapserv.exe in a directory where IIS can access it
and where it can Execute it.
first, put your executable in c:\inetpub\scripts\ .
second, check in the Internet Information Services MMC that the scripts
directory exists. It is a virtual directory which should point to
third, change in the form tag tha action as the folowing:
++++ <form method=GET action="/scripts/mapserv.exe"> ++++++
You can let the rest unchanged.
Your problem should be fixed.
Cordialement
Léo Goehrs
