[Mapserver-users] trouble with querymap
Frank Koormann frank.koormann at intevation.de
Fri Dec 27 07:01:14 EST 2002
* David Rafkind <daver at umiacs.umd.edu> [021223 19:04]:
> On Thu, Dec 19, 2002 at 03:00:56PM +0100, Frank Koormann wrote:
> > You can query only layers for which a template is defined.
> > By adding a "map_layer_0_template=%22%22" to your URL I get the result
> > map.
> Thanks a lot, that worked perfectly. However, i would say that requiring a
> template (which is ignored) just to create the querymap is somewhat of a
> mis-feature.
Hmm, it is not straight forward, but it shortens the mapfile. Otherwise
a second attribute would be necessary to identify if a layer is
queryable or not.
Cheers,
        Frank
Frank Koormann                             <frank.koormann at intevation.de>
 Professional Service around Free Software       (http://intevation.net/)
 FreeGIS Project                                 (http://freegis.org/)
