[Mapserver-users] got the demo running
Daniel Morissette morissette at dmsolutions.ca
Mon Dec 30 14:09:27 EST 2002
The query results template in the demo uses a JavaScript
document.write() call to produce this "download GML version" link:
      document.write("<p><a
href=\"[program]?map=[map]&REQUEST=GetFeatureInfo&query_layers=" +
layers.replace(/ /g, ',') +
"&VERSION=1.1.0&x=[img.x]&y=[img.y]&INFO_FORMAT=gml&bbox=" +
bbox.replace(/ /g, ',') +  "\">download GML version</a></p>\n")
The '\' characters are not escaped as '\\' the way they should be in a
JavaScript string, that's why they disappear in the resulting URL.
Change your config to use forward slashes ('/') in your map path, i.e.
"c:/mapserver_demos/itasca/demo.map"   This will work fine on Windoze
and will work around this JavaScript issue.
Daniel
Uffe Kousgaard wrote:
> Hi list,
> I have finally got the standard demo running. There is however one issue
> left: When I query the map and list the available objects, there is a
> button with this text:
> Instead of linking to "c:\mapserver_demos\itasca\demo.map" it links to
> "c:mapserver_demositascademo.map". Is there a setting somewhere to
> define the /  or \ ?
> I use IIS5 + mapserver 3.6.3
> TIA
> Uffe
