[mapserver-users] POSTGIS/Mapscript DB connection is not closing (FWD)
teb
teb at mallit.fr.umn.edu
Mon Feb 4 15:15:45 EST 2002
------------- Begin Forwarded Message -------------
Date: Mon, 04 Feb 2002 12:19:20 -0800
X-Accept-Language: en
MIME-Version: 1.0
To: mapserver-info at lists.gis.umn.edu
Subject: POSTGIS/Mapscript DB connection is not closing
Content-Transfer-Encoding: 7bit
After I use mapscript to query my postgis layer in my map, the
postmaster that got run never dies/closes?
Anyone have any idea on why this might be happening?
Hhere is an exerpt of the offending mapscript code...
//turn the point where the user clicked on the image into a lat/long
co-ordinate
$pt = ms_newPointObj();
$lat = get_lat($map->extent->minx, $map->extent->maxx, $img_x,
700);
$long = get_long($map->extent->miny, $map->extent->maxy, $img_y,
350);
$pt->setXY($lat, $long);
//query the postgis layer
$layer = $map->getLayer(5);
$err = @$layer->queryByPoint($pt, MS_MULTIPLE, $missby);
if($err == MS_FAILURE){
echo "<font size=4 color=red>There were no results found, try
zooming in closer.</font>";
}else if( $err == MS_SUCCESS){
$layer->open($img->shapepath);
//save the query results into an array
$i=0;
$result = $layer->getResult($i);
while($result != FALSE && $i < 5){
$shape = $layer->getShape($result->tileindex,
$result->shapeindex);
$value = $shape->values;
$val[$i] = $value;
$i++;
$results_found =1;
$layer->close;
As well as the postgid layer in the mapfile:
LAYER
CONNECTIONTYPE postgis
NAME "mypostgis"
DATA "point from usage_points"
CONNECTION "host=ox user=postgres port=5555 dbname=postgis_usage"
STATUS DEFAULT
TYPE POINT
CLASS
TEMPLATE query.html
MINSIZE 10
SYMBOL star
COLOR 250 0 25
END
END
,thanks
-Jeff
------------- End Forwarded Message -------------
