[mapserver-users] DBF Queries
Francisco Delgado
delgadof at marn.gob.sv
Thu Feb 7 18:18:14 EST 2002
Yes, it has changed. Now both TEMPLATE, HEADER and FOOTER definitions go
inside the QUERY object of each LAYER object, but I think what Fran is
trying to do is to query a database that gets some records with
Latitude/Longitud data within the returned fields and plot them over an
existing map. Could somebody tell us (I want to do the same) how to do that?
Atentamente,
Francisco Jose Delgado - Director de Informatica MARN
http://www.marn.gob.sv
-----Mensaje original-----
De: owner-mapserver-users at lists.gis.umn.edu
[mailto:owner-mapserver-users at lists.gis.umn.edu]En nombre de Pushkar
Pradhan
Enviado el: Thursday, February 07, 2002 1:34 PM
Para: Francisco
CC: mapserver-users at lists.gis.umn.edu
Asunto: Re: [mapserver-users] DBF Queries
I am giving you an example from MS 3.3 I don't know whether it is changed,
but you will get an idea of a simple query.
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
This will enable query for only this layer:
LAYER
NAME majr
TYPE LINE
STATUS ON
DATA majr
CLASS
NAME "Major Rivers"
COLOR 0 0 255
END
HEADER "majr_header.html"
FOOTER "majr_footer.html"
QUERY
TEMPLATE "majr.html"
END
TOLERANCE 5
END # end of layer object - major rivers
The majr.html is the main file here which contains attrib. from your
.dbf file:
<tr><td>[LENGTH]</td><td>[MAJR_]</td><td>[MAJR_ID]</td><td>[NAME]</td><td>[R
NUM]
</td></tr>
length, name etc.. are attribs. from the dbf file.
_header.html: (only for html presentation)
<font size+1><b>Layer: majr</b></font><p>
<table cellpadding=5 cellspacing=2 border=0>
<tr
bgcolor=#CCCCCC><th>LENGTH</th><th>MAJR_</th><th>MAJR_ID</th><th>NAME</th><t
h>RNUM</th></tr>
The footer is simply html decoration:
</table><p>
> Hello all.
> First of all, thank you for your help with the Angle labels.
> Now, I'm looking for documentation or examples about queries to DBF files.
> I use ArcView files (Shp, DBF, Shx) and i would like to show some points
> from a query in a map.
> Someone know where I can find something about it?.
> Thank you,
> Regards!
> Fran.
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
