[mapserver-users] Beginner question - UK projections
Frank Warmerdam
warmerdam at pobox.com
Fri Feb 8 10:18:49 EST 2002
dchampion at clacks.gov.uk wrote:
> I'm a new Mapserver user, and not a geographer, so this may be a simple
> question! Any help would be most gratefully received.
> I've compiled v3.5 with PROJ4 support and the demo works beautifully.
> I have a shapefile with data of my local area, Clackmannanshire in
> Scotland. My problem is how to get this data to display. I'm fairly sure
> it has something to do with projections, but that's where my understanding
> runs dry.
> So, how do I determine:
> a) What extent values to use
> b) What values to put in the PROJECTION block in the .map file?
> I've taken EXTENT values from ArcView based on UK OS grid references, and
> I've tried this for projection, based on my scant understanding, but no
> data is displayed:
> PROJECTION
> "proj=tmerc"
> "ellps=airy"
> "zone=31"
> "north"
> "no_defs"
> END
Daniel,
The UK National Grid should be represented as:
PROJECTION
"proj=tmerc"
"lat_0=49.000000000"
"lon_0=-2.000000000"
"k=0.999601"
"x_0=400000.000"
"y_0=-100000.000"
"ellps=airy"
"towgs84=375,-111,431,0,0,0,0"
END
The "towgs84" portion is only necessary if you will have data in other
datums.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
