[mapserver-users] Mapserver CGI variable: img. (FWD)
Frank Koormann
frank.koormann at intevation.de
Sun Feb 10 09:03:01 EST 2002
Tim,
* teb (teb at mallit.fr.umn.edu) [020208 18:29]:
> ------------- Begin Forwarded Message -------------
> Content-return: allowed
> Date: Thu, 07 Feb 2002 08:51:14 -0800
> From: "Webber, Tim MCF:EX" <Tim.Webber at gems1.gov.bc.ca>
> Subject: Mapserver CGI variable: img.
> To: "'mapserver-info at lists.gis.umn.edu'" <mapserver-info at lists.gis.umn.edu>
> MIME-version: 1.0
> Content-transfer-encoding: 7BIT
> I am using an img src tag to run mapserver. It almost does what I want. 4
> gifs are created and dumped into my tmp directory. My problem is that I
> want to be able to control the name of these gifs. I tried setting the img
> cgi variable like in the following tag (&img=data1) hoping that that would
> set the value of the main map gif but it does'nt work. The map name still
> comes out something like data110130986502268.gif. Is there a way to
> execute mapserver like I have below (which again works) and be able to set
> the value of the gif's that get created and dumped into my tmp directory?
Mostly:
o The "NAME" Tag of the mapfile defined the start of the file name(s)
o Using the CGI-Parameter "ID" you can replace the uniq session id based
on system time and process id by an identifier of your choice.
o The "leg", "ref" etc will still remain to differentiate the images
generated within one session.
See
http://mapserver.gis.umn.edu/doc/mapfile-reference.html
and
http://mapserver.gis.umn.edu/doc/cgi-reference.html
for more details.
Regards,
Frank
Frank Koormann <frank.koormann at intevation.de>
Professional Service around Free Software (http://intevation.net/)
FreeGIS Project (http://freegis.org/)
