[mapserver-users] Can i combine Rosa and USEMAP
Azimuth, Erwin Perik
perik at azimuth.nl
Thu Feb 14 05:05:57 EST 2002
Hi All,
I created an image using a HTML USEMAP like following:
<MAP NAME="points">
<AREA HREF="#" ALT="info about the point" TITLE="Products" SHAPE=CIRCLE
COORDS="251,143,50" >
.....repeated for every POINT in a shape
</MAP>
//creating the image:
echo"<IMG SRC=$url USEMAP=#points BORDER=0 WIDTH=$gpoMap->width
HEIGHT=$gpoMap->height NAME=clickmap";
USEMAP=#points --> creates circle-references for every point. Circle (50
radius) around the coordinates of the point.
When hovering with the mouse over the created circle-reference info is
displayed using the HTML ALT option.
'Normally' an image would look something like:
echo"<INPUT TYPE=image SRC=$url BORDER=0 WIDTH=600 HEIGHT=450 NAME=zoommap>";
As it's all based on Gmap i have not found an option to add this to the
Rosa applet.
Is it possible to combine Rosa with the Usemap secribed above.
Thanks,
Erwin
