[mapserver-users] What's wrong with this string?
Lyndon Zimmermann
lyndon.zimmermann at adelaide.edu.au
Wed Feb 20 17:24:58 EST 2002
Steve,
Bingo! Thanks.
Thanks also Erwin, I had found that one (<input type="hidden"
name="imgext" value="[mapext]">) myself but otherwise it would have been
a vital clue.
Lyndon Z
Steve Lime wrote:
> Imgext is only used to describe an existing image displayed by mapserver
> and needs x,y coordinates (in image units) to be useful. I think what
> you want to use mapext instead. Mapext refers to the extent of the map
> to be created and is the standard way to initialize an application.
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> Lyndon Zimmermann <lyndon.zimmermann at adelaide.edu.au> 02/19/02 21:55
> PM >>>
> I'm reworking an enquiry front end, and currently generate an initiate
> string:
> http://sg211.gisca.adelaide.edu.au/cgi-bin/mapserv/mapserv?map=..%2Fhtdocs%2Fau_afs_mapserver%2Fau_afs_nojava.map&mode=browse&layer=state_boundaries&zoomsize=2&imgext=855342.0+-4343315.0+1458169.0+-3768371.0&resources=infield&pop=999&roads=999&elec=999
> It appears to ignore the imgext, and just uses the defaults. Any
> clues? The values are an Albers projection, I obtained by zooming to my
> region of interest and copying the command string that produced it.
> Lyndon Zimmermann
> Lyndon Zimmermann
> BE (Mech Adelaide) Grad Dip Bus Admin (UniSA)
> LOW RAINFALL AGROFORESTRY RESEARCH UNIT
> Affiliated with the CRC for Plant Based Management of Dryland Salinity
> University of Adelaide Department of Agronomy and Farming Systems
> Physical address: Hannaford Building (via Gate 3) Waite Campus, South
> Australia
> Postal: Adelaide University, PMB1 Glen Osmond, SA 5064, Australia
> Dir (Soil and Water) +61-8-8303 6571 Mob 0414 91 4577
> Fax +61-8-8303 6717 email lyndon.zimmermann at adelaide.edu.au
> Bionergy Atlas Website:
> http://www.gisca.adelaide.edu.au/~lzimmerm/bioenergy_atlas/atlas_index.html
> Unless otherwise stated, the content of this message and attachments may
> be forwarded or quoted, with due acknowledgement. No representation is
> made that this email is free of viruses. Virus scanning is recommended
> and is the responsibility of the recipient.
Lyndon Zimmermann
Australia
