[mapserver-users] Compilation problem
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Fri Feb 22 16:23:52 EST 2002
Try recompiling apache with the foll. options:
configure --enable-module=so --enable-rule=SHARED_CORE --enable-shared=max
> Hello list.
> Please, I have installed apache with this configure:
> ./configure --enable-module=so
> php 4.06 with:
> ./configure --with-dbase=yes
> --with-system-regex
> --with-png=yes
> --without-ttf
> --with-apxs=/usr/local/apache/bin/apxs
> --with-mysql
> --with-pgsql
> --with-config-file-path=/etc
> Mapserver 4.05 with:
> ./configure --with-gd --with-php=/programas/php-4.0.6 --with-apxs
> --with-sde --with-ttf
> Everything works fine, the configure and the make, but when I try to
> load the module, the page in the browser says:
> Warning*: Unable to load dynamic library
> '/usr/local/lib/php/extensions/php_mapscript.so' - php_mapscript_util.o:
> cannot open shared object file: No such file or directory in
> */usr/local/apache/htdocs/prueba.php* on line *2*
> Am I missing something?
> I've searched on the list, but it points to re-compile apache.
> I'm using Suse 7.3
> Thanks a lot,
> Vladimir Guzmán R.
> www.main-task.com
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
