[mapserver-users] Raster reprojection
Vladimir Guzmán
vguzman at bigfoot.com
Tue Feb 26 09:35:08 EST 2002
I'm sorry to disturb you again with the same problem, but I can not
figure out why do I have to install gdal library,
if I didn't need it with MS 3.4.
The error appears when I use a tiff image as background map, so I
decided to use a png, with the same result:
*Warning*: MapServer Error in msDrawRasterLayer( PNG ): Raster
reprojection supported only with the GDAL library. in
*/usr/local/apache/htdocs/sig/admin/templates/mapa_form.php* on line *246*
*Fatal error*: Call to a member function on a non-object in
*/usr/local/apache/htdocs/sig/admin/templates/mapa_form.php* on line *247*
But the error doesn't appear every time, only in some zooms.
Do I have to install gdal anyway?
Why?
Thanks a lot,
Vladimir Guzmán R.
www.main-task.com
Pushkar Pradhan wrote:
>You should have to recompile mapserver with the --without-tiff option
>and --with-gdal=/path/to/gdal-config
>Otherwise what happens is that when MS comes across the TIFF img. it calls
>the TIFF libs. and GDAL libs. will never be called.
>>Hello.
>>I'm having a problem with ms.
>>>From time to time, I get an error:
>>Warning: MapServer Error in msDrawRasterLayer( TIFF ): Raster reprojection
>>/usr/local/apache/htdocs/sig/templates/mapa_form.php on line 234
>>I've read in the mail-list, and Frank Warmerdam says that it is necessary to
>>reconfigure without tiff support.
>>Reconfigure what? GD? MS? PHP?
>>My configure options:
>>PHP:
>>./configure --with-dbase=yes --with-system-regex --with-png=yes --without-ttf
>>--with-apxs=/usr/local/apache/bin/apxs --with-mysql --with-pgsql
>>--with-config-file-path=/etc
>>MS:
>>./configure --with-gd=/programas/gd-1.8.4 --with-php=/programas/php-4.0.6
>>--with-apxs=/usr/local/apache/bin/apxs --with-sde --with-ttf
>>Thanks a lot,
>>Vladimir Guzmán
>>www.main-task.com
>PUSHKAR S. PRADHAN
>Research Assistant
>MISSISSIPPI STATE UNIVERSITY,
>STARKVILLE, MS 39759.
>Engineering Research Center
>Box 9627
>Mississippi State, MS 39762-9627
