[mapserver-users] Projection Change
Grant Marblestone
GrantM at ATSER.com
Wed Jan 2 09:36:41 EST 2002
Howdy,
I was wondeirng if there was a way to change a map's projection, Actually i
want to know if you can convert it. I know about Proj4, however i just want
to convert the map itself from nad83 to gws84, possible?
OR, I have a map with nad83 and i also have some gws84 gps positions that
dont line up when i apply the proj4 projection from 84 --> 83. I live in
Houston, TX and the web page says These data sets are in the State Plane
Coordinate System, NAD 83. Map Units = feet
Thanks,
Grant
I am going to go ahead and paste my map file below i hope no one minds.. and
i think i will send a link to the shp file that uses nad83.
LINK TO NAD83 SHP FILE
http://www.co.harris.tx.us/hcedweb/GIS/majrds_rds.exe
MAP FILE
map
extent 2917058.5 13747172.0 95387545.0 29956950.0
imagecolor 255 255 255
name "steel3"
shapepath "data"
size 600 600
status on
symbolset "symbols/all.sym"
units meters
PROJECTION #set for output gif / png datum set same as map
"init=epsg:32614" # epsg:26914" # all nad83 followed by gws84
END
# 1 scalebar #none
scalebar
backgroundcolor 255 255 0
color 255 255 255
intervals 4
outlinecolor 0 0 0
size 200 7
status on
style 0
transparent true
units meters
# 1 label #none
label
backgroundcolor 0 0 0
color 255 255 0
size tiny
end
end
# 2 layer mtfp_nad83
layer
classitem "FNODE_"
data "mtfp_nad83"
group "mtfp_nad83"
labelcache on
labelitem "FNODE_"
name "mtfp_nad83"
postlabelcache true
status on
type line
METADATA
"wms_title" "Roads"
END
PROJECTION # projection needs to be set for map
"init=epsg:32614" # changed here to suit nad83
END
# 1 class mtfp_nad83_1
class
backgroundcolor 128 128 128
color 128 128 128
name "mtfp_nad83_1"
outlinecolor 0 0 0
end
end
# 3 layer Grant
layer
classitem "ContractID"
data "Grant"
group "Grant"
labelcache on
labelitem "ContractID"
name "Grant"
postlabelcache true
status on
type point
METADATA
"wms_title" "Points"
END
PROJECTION
"init=epsg:26914" #code for wgs84
END
# 1 class Grant_1
class
color 128 128 128
name "Grant_1"
outlinecolor 0 0 0
end
end
# 4 web steel3.html
web
footer "steel3_footer.html"
header "steel3_header.html"
imagepath "c:\phpdev\www\tmp\"
imageurl "/tmp/"
template "steel3.html"
METADATA
"wms_title" "Steel3"
END
end
# 5 querymap hilite
querymap
color 255 0 0
size 200 200
status on
style hilite
end
# 6 reference graphics/reference.gif
reference
color -1 -1 -1
image "graphics/reference.gif"
outlinecolor 255 0 0
size 120 120
status on
end
# 7 legend #none
legend
keysize 18 12
status on
# 1 label #none
label
color 0 0 89
size medium
type bitmap
end
end
end
