[mapserver-users] Help: MS 3.5 PHP3 MapScript Install
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jan 4 12:32:28 EST 2002
Additional info: THe apache error_log has:
httpd: error in loading shared libraries:
/usr/lib/apache/php_mapscript.so: undefined symbol:
_register_list_destructors
in it. So this looks like the problem, but How do I fix it?
-Steve
Stephen Woodbridge wrote:
> Hi all,
> I can't get PHP3 Mapscript to run on my RH 6.2 Linux with Apache.
> It seems to have built OK and I moved the php_mapscript.so to the
> /usr/lib/apache directory and tried to run the phpinfo_mapscript.phtml
> script via the server but all I get is the "Document Contained No Data"
> dialog box which usually indicates the process crashed.
> Here is how I configured it:
> ./configure --enable-shared --enable-modules --enable-lzw
> --without-magick-plus-plus --with-perl-options=PREFIX=/usr --with-ogr
> --with-gdal --with-wmsclient --with-proj
> --with-php=../../linux/php-3.0.16 --with-apxs=/usr/sbin/apxs
> Any ideas on what to check or how to debug this?
> -Steve
