[mapserver-users] Help: MS 3.5 PHP3 MapScript Install
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jan 4 23:58:07 EST 2002
OK, So I read that before and my system had mod_so so I thought it was
OK, but I guess not. That's OK, I decided to built a newer apache with
DSO and fought through a plague of problems and finally got apache and
php3 working as DSO (but I still have to go back and fix php4 and
mod_perl which broke doing this) ...
NEW PROBLEM! (I seem to get stuff on regex stuff alot :)
Now I tried to rebuild mapserver 3.5 with mapscript using:
./configure \
--with-perl-options=PREFIX=/usr \
--with-ogr --with-gdal --with-wmsclient --with-proj \
--with-php=/home/woodbri/linux/php-3.0.16 \
--with-apxs=/usr/sbin/apxs
and get down to:
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
-DUSE_PROJ_API_H -DUSE_WMS -DUSE_WMS_LYR -DUSE_TIFF -DUSE_JPEG
-DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_TTF
-DGD_HAS_GDIMAGEGIFPTR -DUSE_OGR -DUSE_GDAL -I/usr/include
-I/home/woodbri/linux/php-3.0.16/regex -I/usr/local/include
-I/usr/local/include -I/usr/local/include
-I/usr/local/include/w3c-libwww -DHAVE_CONFIG_H
/home/woodbri/linux/php-3.0.16/regex/regcomp.c -o
/home/woodbri/linux/php-3.0.16/regex/regcomp.o
In file included from /home/woodbri/linux/php-3.0.16/regex/regcomp.c:14:
/home/woodbri/linux/php-3.0.16/regex/cclass.h:8: warning: missing braces
around initializer for `cclasses[0]'
and a whole lot more warnings like the last until make dies!
I assume that the references to my php dir are an attempt to reuse the
regex code built into php. Does this mean I need to configure php
differently or what? And since I JUST built php WHY is it compiling it
again and putting the .o back over there instead of locally!
OK, Don't ask me why (I didn't do a make clean on php) but that dir had
not been built, presumably because php picked up the regex which is
installed as a system library. I did a make in this dir and went back to
mapserver and every think built ok.
So, I cp php_mapscript.so /etc/httpd/modules/ over and say cool now I
can get the mapscript/php test to work .... NO such luck!!!!
I still get the:
[Fri Jan 4 22:26:31 2002] [notice] Accept mutex: sysvsem (Default:
sysvsem)
httpd: error in loading shared libraries:
/usr/lib/apache/php_mapscript.so: undefined symbol:
_register_list_destructors
So 5 hours later and I'm back where I started. I must have mised
something. Maybe a good nights sleep and I will see it in the morning.
[root at linus httpd]# /sbin/httpd -l
bash: /sbin/httpd: No such file or directory
[root at linus httpd]# /usr/sbin/httpd -l
Compiled-in modules:
http_core.c
mod_so.c
suexec: disabled; invalid wrapper /usr/sbin/suexec
phpinfo() reports:
Configure command: ./configure '--prefix=/usr'
'--with-apxs=/usr/sbin/apxs' '--with-config-file-path=/etc/httpd'
'--enable-safe-mode'
'--enable-versioning' '--enable-force-cgi-redirect=yes'
'--enable-discard-path=yes' '--with-exec-dir=/usr/bin'
'--with-system-regex'
'--disable-debug' '--with-zlib' '--with-gdbm' '--enable-debugger'
'--enable-magic-quotes' '--enable-track-vars' '--enable-sysvsem'
'--enable-sysvshm' '--enable-track-vars' '--with-xml'
'--with-ftp' '--with-jpeg' '--without-ttf' '--with-gd'
'--with-mysql=/usr'
php3.ini file path is set to: /etc/httpd
I checked to make sure I have the -rdynamic in the php Makefile, NO the
little beggar some how escaped again! It it a real pain to keep adding
it and losing it every time you run configure. So I add it again; make
clean; make; su; make install; restart apache; Still does not work!
I appreaciate the help. This falls into the "It just isn't easy!"
catagory.
-Steve
Daniel Morissette wrote:
> Stephen Woodbridge wrote:
> >Additional info: THe apache error_log has:
> >in it. So this looks like the problem, but How do I fix it?
> This happens if your php executable (if you compiled PHP as a CGI) or
> your httpd binary (if PHP is compiled statically into Apache) was not
> linked to support loading shared libraries. It has to be relinked using
> the "-rdynamic" option (on Linux) which will allow loading of shared
> libraries.
> See also:
> http://www2.dmsolutions.ca/mapserver/php_mapscript/php_mapscript_faq.html#4.3
> Daniel
