[mapserver-users] truetype weirdness
thorsten fischer
thfischer at mapmedia.de
Mon Jan 7 10:38:58 EST 2002
Robert, Daniel,
(and: list :) ),
I have recompiled gd with some shared library magic, and also recompiled
mapserver with that, using my latest cvs checkout. The result is still
the same: error. See below for the layer from the mapfile that causes
the error, the error message itself, the mapserver version string and
the output of ldd (btw I believe that libcrypto and libresolv are part
of glibc; otherwise I would scratch my head even more than I do at the
moment). There is no other libgd installed on the system.
Reverting to freetype-1.3 does not fix the problem either btw. I tried
to track down the source of the error by removing parameters of the
label section - to no avail. Bitmap fonts still work fine.
<ServiceException>
msGetLabelSize(): TrueType Font error. Could not find/open font
</ServiceException>
grobi:/usr/local/GIS/apache/cgi-bin # ./mswms -v
MapServer version 3.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
grobi:/usr/local/GIS/apache/cgi-bin # ldd mswms
libgd.so.1 => /usr/local/GIS/lib/libgd.so.1 (0x40028000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40059000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x40078000)
libpng.so.2 => /usr/lib/libpng.so.2 (0x400ac000)
libz.so.1 => /lib/libz.so.1 (0x400de000)
libtiff.so.3 => /usr/lib/libtiff.so.3 (0x400ed000)
libproj.so.0 => /usr/local/GIS/lib/libproj.so.0 (0x40130000)
libgdal.1.1.so => /usr/local/GIS/lib/libgdal.1.1.so (0x4016f000)
libpq.so.2 => /usr/local/GIS/pgsql/lib/libpq.so.2 (0x404aa000)
libm.so.6 => /lib/libm.so.6 (0x404bc000)
libc.so.6 => /lib/libc.so.6 (0x404de000)
libgeotiff.so => /usr/local/GIS/lib/libgeotiff.so (0x40604000)
libdl.so.2 => /lib/libdl.so.2 (0x40628000)
libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3
(0x4062c000)
libcrypt.so.1 => /lib/libcrypt.so.1 (0x4067a000)
libresolv.so.2 => /lib/libresolv.so.2 (0x406a7000)
libnsl.so.1 => /lib/libnsl.so.1 (0x406b9000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
LAYER
NAME "g_sie1_1099_pois_annotation"
METADATA
"wms_title" "Siedlungsgebiete (Punkte) Beschriftung"
END
PROJECTION
"init=epsg:4318"
END
TYPE ANNOTATION
STATUS on
MAXSCALE 300000
DATA "shapes/g_sie1_1099_pois"
LABELITEM "GN"
CLASSITEM "GN"
CLASS
EXPRESSION /./
LABEL
COLOR 0 0 0
OUTLINECOLOR 255 255 255
TYPE TRUETYPE
FONT arial
SIZE 10
POSITION CR
PARTIALS TRUE
BUFFER 1
END
END
END
cheers,
thorsten
Thorsten Fischer thfischer at mapmedia.de
MapMedia - Kartographie und raumbezogene Informationssysteme
Am Borsigturm 42
13507 Berlin
Deutschland
http://www.mapmedia.de tel: +49 (0)30 43032102
