[mapserver-users] Restricting zooms into a map
stepan.kafka at centrum.cz stepan.kafka at centrum.cz
Mon Jan 7 13:49:54 EST 2002
I think, the problem is caused that you overwrite original map
extent twice. Try copy $map->extent to temporary variable for
using in the second command.
Stepan
______________________________________________________________
> Od: thorsten fischer <thfischer at mapmedia.de>
> Komu: mapserver-users at lists.gis.umn.edu
> CC:
> Datum: 07 Jan 2002 19:53:29 +0100
> Předmět: [mapserver-users] Restricting zooms into a map
> Ladies and gentlemappers,
> Using php mapscript, i want to keep users from zooming deeper
into a map
> than to a certain scale; say, 25000 for this example. I think
the proper
> to do this is to perform the zoom, then checking the scale and
if the
> scale does not match what I want, I am zooming out again.
> So I do the following (zooms etc. are done with zoomPoint() in
my app,
> which works fine):
> $map -> zoomPoint ($factor, $point, $X, $Y, $rect, $map ->
extent);
> if ($map -> scale < 25000) {
>   $map -> zoomScale (25000, $point, $X, $Y, $rect, $map ->
extent);
> Unfortunately, calling zoomScale() does not change anything.
Are things
> done using buffering in some way, i.e. do I have to 'flush'
changes
> before I do another zoom?
> cheers,
> thorsten
> Thorsten Fischer        thfischer at mapmedia.de
> MapMedia - Kartographie und raumbezogene Informationssysteme
> Am Borsigturm 42
> 13507 Berlin
> Deutschland
> http://www.mapmedia.de tel: +49 (0)30 43032102
Centrum pro milovníky peněz
http://finance.centrum.cz
