[mapserver-users] [Fwd: Simple question]
Richard Greenwood Rich at GreenwoodMap.com
Mon Jan 7 18:00:22 EST 2002
I have pasted a simple thematic layer definition below. You define the
colors or patterns for the thematic map in the MAP file. The "Zoning" field
in my table has a two character field that I want to thematically map (the
CLASSITEM). Then I define a class for each zone. The important thing in
each class is the EXPRESSION. You only need to give a class a NAME if you
want it to have a legend.
Rich
LAYER
         NAME "Zoning_Thematic"
         DATA Zoning
         TYPE POLYGON
         CLASSITEM Zoning
                 CLASS NAME "AC - Auto-Urban Commercial"
                         EXPRESSION 'AC' COLOR 255 144 200       END
                 CLASS NAME "BC - Business Conservation"
                         EXPRESSION 'BC' COLOR 255 0 0           END
                 CLASS NAME "BP - Business Park"
                         EXPRESSION 'BP' COLOR 224 0 224         END
                 CLASS NAME "MH - NC, Mobile Home Park"
                         EXPRESSION 'MH' COLOR 255 192 0         END
                 CLASS NAME "OP - Office Professional"
                         EXPRESSION 'OP' COLOR 255 255 0         END
                 CLASS NAME "PA - Park"
                         EXPRESSION 'PA' COLOR 0 176 88          END
                 CLASS NAME "PD - NC, PUD"
                         EXPRESSION 'PD' COLOR 255 208 255       END
                 CLASS NAME "PR - PUD for Planned Resort"
                         EXPRESSION 'PR' COLOR 255 208 160       END
                 CLASS   NAME "RU - Rural"
                         EXPRESSION 'RU' COLOR 160 255 160       END
                 CLASS NAME "SF - NC, Single Family"
                         EXPRESSION 'SF' COLOR 176 229 255       END
                 CLASS NAME "SP - Public / Semi-Public"
                         EXPRESSION 'SP' COLOR 0 160 160         END
                 CLASS NAME "SU - Suburban"
                         EXPRESSION 'SU' COLOR 255 160 128       END
END     # end of "Zoning_Thematic" layer object
At 04:20 PM 1/7/2002 -0500, you wrote:
>  Received: from xcalibur.dmsolutions.ca (www2.dmsolutions.on.ca
> [209.217.116.146])
>         by in2.magma.ca (Magma's Mail Server) with ESMTP id g07GjvfR017227;
>         Mon, 7 Jan 2002 11:45:57 -0500 (EST)
>Received: from gnome04.sovam.com (gnome04.sovam.com [194.67.1.185])
>         by xcalibur.dmsolutions.ca (8.11.2/8.11.2) with ESMTP id g07GcnP11915
>         for <dev at dmsolutions.ca>; Mon, 7 Jan 2002 11:38:49 -0500
>Received: from ts3-a63.Voronezh.dial.sovam.com ([194.186.96.191]:15878 "EHLO
>         194.186.96.191" ident: "NO-IDENT-SERVICE[2]" whoson: "voischev"
>         smtp-auth: <none> TLS-CIPHER: <none> TLS-PEER: <none>)
>         by gnome04.sovam.com with ESMTP id <S1121188AbSAGQpi>;
>         Mon, 7 Jan 2002 19:45:38 +0300
>Date:   Mon, 7 Jan 2002 19:44:41 +0300
>From: Voischev Alexander <voischev at online.ru>
>X-Mailer: The Bat! (v1.53d)
>Reply-To: Voischev Alexander <voischev at online.ru>
>X-Priority: 3 (Normal)
>Message-ID: <5319692035.20020107194441 at online.ru>
>To: dev at dmsolutions.ca
>Subject: Simple question
>MIME-Version: 1.0
>Content-Type: text/plain; charset=us-ascii
>Content-Transfer-Encoding: 7bit
>X-Mozilla-Status2: 00000000
>Hello.
>I have a one simple question. I want to create a thematic map,
>but I don't know how I may set the custom color to one shape object by
>the php-script. My aim is assignment the calculated colors to the shapes
>in some layers. How I can do that ?
>Thanx.
>Best regards,
>  Voischev Alexander       mailto:voischev at online.ru
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
(307) 733-0203
http://www.GreenwoodMap.com
