[mapserver-users] RE: [MapServer-users] Blank Image when zoom ing
Nuno Alves est-n-alves at ptinovacao.pt
Tue Jan 8 06:37:51 EST 2002
I've allready change the MINSCALE and MAXSCALE properties for each data
layer and for WEB properties too. I´ve changed
too the extensions of the map again, but nothing. I have had another idea,
that was to "clean the trash" from my map
files, that i allready did, but the problems persists.
I've attached my MAP file to this mail. Any help would be appreciated.
	Thanks,
		Nuno Alves
-----Original Message-----
From: Fawcett, David [mailto:david.fawcett at moea.state.mn.us]
Sent: sexta-feira, 4 de Janeiro de 2002 16:16
To: mapserver-users at lists.gis.umn.edu; 'Nuno Alves'
Subject: [mapserver-users] RE: [MapServer-users] Blank Image when
zooming
Not knowing much about your application, it sounds to me like your layers
are scale dependent.  In other words, they are set to only show between a
maximum and a minimum scale value.
Check the MINSCALE and MAXSCALE properties for each of your data layers.
Are the layers set to show at the scales you want to see them at?
If this doesn't work, post the text of your Map file.  Perhaps some of the
other folks on the list could diagnose it from the mapfile.
David.
David J. Fawcett
GIS / Databases
MN Office of Environmental Assistance
520 Lafayette Rd N
St. Paul, MN 55155
651.215.0200
> From: 	Nuno Alves[SMTP:est-n-alves at ptinovacao.pt]
> Sent: 	Friday, January 04, 2002 9:41 AM
> To: 	mapserver-users at lists.gis.umn.edu; Nuno Alves
> Subject: 	[mapserver-users] Blank Image when zooming
> Hi all!  Sorry about my english.
> I am using mapserver 3.5 (and i'm new at this, i just recently started
with
> nightly builds), compiled with postgis, OGR and gd-1.2 to have gif
support.
> I> ´m using MAPINFO files to produce a map of an exposition field with
> information about streets, MB services, restaurants, phones, and a lot of
> other
> important information for visitors.
> My problem is the following:
> I open my web page and i can´t see some layers. When i zoom in some of
them
> appear and others disapear. As for zoom out, is the same. I allready
> change the map extensions but the problem continues, note in the same zoom
> positions but in others.
> Any help would be aprecciated. Thanks.
> Best regards,
>  <<...OLE_Obj...>>
> Nuno Ricardo Ribeiro Alves
> PT Inovação, S.A.
> Serviços e Redes Móveis
> * R. Engº José Ferreira Pinto Basto - 3810 Aveiro
> * mailto:est-n-alves at ptinovacao.pt
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020108/d7d34b8f/demo.obj
