[mapserver-users] attribute query problems in 3.5
Jensen, Hannah ERDC-CRREL-NH
Hannah.Jensen at erdc.usace.army.mil
Tue Jan 8 11:41:34 EST 2002
Thanks very much! That did the trick.
Cheers,
Hannah
-----Original Message-----
From: stepan.kafka at centrum.cz [mailto:stepan.kafka at centrum.cz]
Sent: Tuesday, January 08, 2002 10:56 AM
To: Jensen, Hannah ERDC-CRREL-NH; mapserver-users at lists.gis.umn.edu
Subject: re: [mapserver-users] attribute query problems in 3.5
Please, check if your features are in map extent (set in your map
file). The MS 3.5 uses it for feature queries.
Stepan Kafka
______________________________________________________________
> Od: "Jensen, Hannah ERDC-CRREL-NH"
<Hannah.Jensen at erdc.usace.army.mil>
> Komu: mapserver-users at lists.gis.umn.edu
> CC:
> Datum: Tue, 8 Jan 2002 10:02:38 -0500
> Předmět: [mapserver-users] attribute query problems in 3.5
> Hello. I'm trying to do an itemnquery to select US states and
territories
> by FIPS code from a shapefile containing unprojected data. It
seems to work
> fine for most states but has trouble with some islands. For
example, Puerto
> Rico works, but Guam doesn't, Hawaii works, but the US Virgin
Islands don't.
> Seems like this should be a data problem, but so far I haven't
found
> anything wrong there. Plus, this worked fine in version 3.4
with the same
> data. Any ideas what could be going wrong? As always, any
help is much
> appreciated.
> Here's an example URL and map file excerpt:
> http://myhost/cgi-bin/mapserv35?
map=../stuff/efilters.map&mapext=shapes&mode
> =itemnquerymap&qlayer=qstates&state=06
> LAYER
> NAME qstates
> DATA /data/stuff/usstates
> TYPE polygon
> STATUS on
> FILTERITEM "ST"
> FILTER "%state%"
> LABELITEM "ST_NAME"
> CLASS
> SYMBOL 'circle'
> OUTLINECOLOR 100 100 100
> SIZE 2
> END
> TEMPLATE state_query.html
> END
> Cheers,
> Hannah
> Hannah Jensen
> (603) 646-4145
> Remote Sensing / GIS Center
> Cold Regions Research and Engineering Lab (CRREL)
> US Army Corps of Engineers
> 72 Lyme Rd, Hanover, NH 03755-1290
Nový vyhledávač pro český internet www.webfast.cz - prostě najde ...
