[mapserver-users] Another Rosa applet question with CGI
Obe, Regina DND\MIS Regina.Obe.PFD at ci.boston.ma.us
Wed Jan 9 11:14:22 EST 2002
Attached is a template using the rosa applet that I adapted from Frank's
version.  This version uses the standard mapserver 3.5 cgi exe and some
javascript.  I haven't tried this with the 3.4 mapserver cgi, but I think it
should work with that too.
It is custom tailored for the project I was working on so the image
locations, layers etc. will need to be changed for general consumption.
Here is a link if you want to see it in action - again this project is still
in beta so things might not work if I am working on them
http://64.67.116.51/mapserv/dnd/htdocs/remsspaces.htm
I'll also post it to the wiki once that is available.
-----Original Message-----
From: Frank Koormann [mailto:frank.koormann at intevation.de]
Sent: Wednesday, January 02, 2002 11:37 AM
To: Obe, Regina DNDMIS
Cc: 'Frank Koormann'; mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] Another Rosa applet question with CGI
Dear Regina, All,
* Obe, Regina     DNDMIS (Regina.Obe.PFD at ci.boston.ma.us) [011228 16:58]:
> Thanks Frank - that example was very handy.  For some reason - the
recenter
> and zoom in boxing didn't work properly with my version of mapserv35 and
the
> rosa applet I was using so I had to modify those sections a bit replacing
> them with javascript calls (I've only tested on IE 5.5. and NS 4.75).  I'm
> posting this in case others ran into similar problems.
As I read your JavaScript Code you are copying the contents of the
INPUT_COORD variable to imgbox or imgxy, depending on the selected
action.
As an alternative one may apply the earlier posted patches to
enable MapServer to interpret these values directly.
See
http://mapserver.gis.umn.edu/majordom_lists/archives/mapserver-users/html/01
12/msg00219.html
for more details.
> I also added
> map-resize capabilities too to the adapted version.  If anyone is
interested
> I can post this version too
I always find it helpful to archive snippets of code to document usage
of a software. Please post it to the list (or wait a bit for the
announced wiki).
Regards,
        Frank
Frank Koormann                             <frank.koormann at intevation.de>
 Professional Service around Free Software       (http://intevation.net/)
 FreeGIS Project                                 (http://freegis.org/)
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020109/147c7118/remsrosa.obj
