[mapserver-users] Reading MapServer output as a theme in Arcview
Tyler Mitchell
TMitchell at lignum.com
Wed Jan 9 12:44:21 EST 2002
Thanks Paul, that appears (will check it out shortly) to be exactly what I
was asking for. Thank you for the term, now I can simply say ArcIMS
emulator for MapServer. Whew - that's a lot easier than trying to describe
what I'm thinking. :) Thanks a bunch.
Tyler
Paul Ramsey
<pramsey at refrac To: v at w.cl
tions.net> cc: Tyler Mitchell <TMitchell at lignum.com>,
mapserver-users at lists.gis.umn.edu
01/08/2002 Fax to:
07:25 PM Subject: Re: [mapserver-users] Reading MapServer output as a theme in
Arcview
As in using it as an "Internet Map Server" data source in Arc8? You will
need an ArcIMS emulator for that...
http://postgis.refractions.net/download.php
Vinko Vrsalovic wrote:
> On Tue, Jan 08, 2002 at 03:06:03PM -0800, Tyler Mitchell wrote:
> > I'd like to have MapServer still serve up an image map but I want this
to
> > appear as a standard theme in Arcview.
> How so? Looks can be configured through LABEL directives, SYMBOLSETS,
FONTSETS,
> etc. Make the image behave like a theme in arcview but in the browser?
> Mapscript is your friend. For instance, you could edit the arcs in the
> browser and save the editing as a shapefile with mapscript, you can even
> generate the shapefile and put a link to it for download.
> What exactly do you mean?
> V. <v at w.cl>
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
